94 steering column work in 93 blazer?
I have a 93 blazer and i cannot turn the key to the off position at all and the shifter shifts out of park and into all the other gears without me pushing on the break and the key falls right out so basically i need to replace my steering column and was wondering if a 94 blazer column would fit in mine. at the junk yard they told me that they are listed as different parts and dont know if it will fit for shure or not. Can anyone verify for me if it will work or not?
94 blazer and 93 blazer will swap out. 94 truck and 93 blazer will not
You just need to change the lock Cyl , not the column.
well the whole column is a bit beat up and would really like to replace the whole thing. I found a 94 blazer on craigslist for 200 bucks....the lady says it just wont start anymore and wants to get rid of it so i figure i got a new steering column and some glass and a set of factory rims(my truck is missing 2 of them ) and that alone is worth 200 bucks
If there are other parts you want then go for it. Pulling the column isn't very hard to do. Just be sure to disconnect the shift rod linkage in the engine bay first and the bolt holding it to the steering shaft. 4 10mm bolts I believe on the firewall and the 2 15mm to drop the column. Just be careful when disconnecting all the wiring.
boo so the doner blazer turned out to be a fullsize and the lady selling it didnt know the difference so i ended up just replacing the ignition cylinder and all is well ......wish i could of been able to take pictures of the breakdown so i could write up a diy artical on it. Not too hard to do at all
Malbo
05-01-2014 12:04 AM
TB2Blazer
04-25-2011 11:20 AM
nucas
04-07-2011 01:05 AM
goerzenl
02-14-2011 06:44 PM
Jays00XJ
11-24-2009 09:08 PM
