89 blazer steering column loose
Old Jan 25, 2011 | 05:53 PM
goerzenl's Avatar
goerzenl is on a distinguished road
Default 89 blazer steering column loose
my steering column is loose right where the tilt joint is. can this be fixed or do i need to try and find a hole new steeering column. please help.
Old Jan 25, 2011 | 06:33 PM
81Z4ME's Avatar
81Z4ME is on a distinguished road
If the Blazer steering column is put together like an 86 IROC steering wheel there are 4 bolts right below that "joint" that work loose. The take a special socket to tighten up and that's after you remove the steering wheel, air bag (if your blazer has one), turn signal switch, etc. There's a bunch of stuff in there to remove before you can get access to those 4 bolts with an extension and socket. The bolt heads look like the tip of a torx head screw driver. I don't remember where I bought my socket set from but you can buy the sockets.
I made up my mind after I got mine back together that the next time that happened (if there is a next time) I'll just go to a junkyard and get a whole other steering column, it was that big of a PITA.
Good luck with yours, whichever way you go.
Old Jan 25, 2011 | 07:06 PM
mr.vls's Avatar
Do a google search on GM tilt column and you will find a few good write ups. I had the same issue and thought about tackling this job myself but I stopped by my idependent shop and they were really familiar with the symptom and repair. Basicly, they take the column apart to get at the mounting bolts remove them add locktight and reassemble. They charged me an hours worth of labor. My column is nice and tight now.
Below is one of the links that gives the repair procedure.
http://www.gnttype.org/techarea/susp..._steering.html
Old Jan 25, 2011 | 08:02 PM
abig84's Avatar
did a few on my trucks. alot of write ups i see only talk about getting at the first two bolts which is easier cause you dont have to take apart alot of stuff. i just pulled the two out, lock tighted them and put them back in... years later they all still work fine
Old Jan 25, 2011 | 10:16 PM
goerzenl's Avatar
thanks for all the info i will let ya know what i do.
Old Jan 26, 2011 | 09:44 AM
mr.vls's Avatar
I bellieve the shop that did mine did two of the three bolts. I can not tell any differance as my steering wheel is nice and tight.
Old Jan 26, 2011 | 06:15 PM
goerzenl's Avatar
local shop said they can do it for 80 so i think ill let them deal with the head for that price lol
Old Feb 7, 2011 | 10:06 AM
mr.vls's Avatar
Did you ever get your steering column worked on?
Old Feb 7, 2011 | 11:12 AM
IrvJr's Avatar
IrvJr is on a distinguished road
I have done it a couple times and it isnt too bad, just tedious. First time just did the 2 that were easily reached, then it happened again and i took it all the way down and loctited the **** out of them.
Old Feb 14, 2011 | 06:44 PM
goerzenl's Avatar
yea i got it fixed at a local shop for 80. for that price i figured they could deal with the head ach lol.
Dirsuper
Jun 29, 2013 11:44 AM
litterbug
Oct 19, 2011 07:50 AM
ussexplorer
Apr 11, 2010 06:53 PM
Jays00XJ
Nov 24, 2009 09:08 PM
ghost
Jun 6, 2009 12:50 PM
