97 blazer cylinder 5 miss fire
Old May 25, 2010 | 11:38 PM
twojustind's Avatar
twojustind is on a distinguished road
Default 97 blazer cylinder 5 miss fire
i have a 97 blazer with a cylinder 5 miss fire i have replaced cap rotor wires and plugs is there anything else cause this?
Old May 26, 2010 | 09:15 AM
ohsofly's Avatar
Yup, a distributor that is on its way out. Take off the cap and rotor and wiggle the shaft side to side, there should be absolutely NO play in it.
You may want to swap the wires around and see if your misfire moves to the wire that used to be on #5
Were the plugs gapped properly? Did you maybe bump #5 when installing it and close the gap? maybe dropped a plug on the ground?
You could also have some crap built up inside the cylinder thats making a red ember that lights off the gas before the spark.
Can you hear a spark jumping when its running? It sounds like a clicking like a BBQ starter or gas stove clicks to start. Can you see a spark jumping when its dark?
You may also want to read around in the 2ND gen forums... This is the 1st gen forum.
tall_ish
Nov 20, 2010 09:05 PM
iloveblazers
Aug 13, 2010 09:33 PM
scott_wheels
Jan 26, 2010 05:49 PM
Tblazer99
Nov 5, 2007 01:12 PM
grdylan
Jun 5, 2007 05:27 PM
