ac compressor wont kick on
I have a 94 s10 blazer 4.3l. The ac needed charged when I got the vehicle. So I disconnected the wire so it would stop kicking on all the time. Well I decided to recharge it and I plunged it back in. But now the compressor won't kick on. I can spin it by hand so its not froze up. I don't understand y it doesn't kick on.
Any help?
Any help?
Too low of system pressure will lock out the compressor clutch. You can either jumper the relay for the clutch or put a jumper wire in the low pressure switch that is on the filter/dryer (large silver canister on the passenger side of the motor). This should allow for the operation of the clutch to pull in refrigerant.
K. How would I go about jumping the low pressure switch?
*UPDATE*
I figured out how to jump it. New prob! The compressor now kicks on every 5 seconds. For about 2 seconds. But doesn't blow cold air?
*UPDATE*
If it didnt have any freon in it when ya first charged it ya should have put a vacume to it if ya didnt any moisture in the lines will freez and fok up compressor .... just my 2 cents
If the system was open to atmosphere and completely depleted of pressure, I would agree. But if a slow leak caused it to bleed down to the point where the low pressure switch was not activating, then a recharge without pump down should work.
Keep on adding refrigerant into the system until it stays on steady and the pressure is in the appropriate zone on the gauge.
skarphace
15
09-17-2012 05:45 PM
insanefirewall
02-20-2011 08:14 AM
gmcjimmy_94
12-30-2010 12:37 AM
jetsmy
08-01-2008 10:10 PM
