Alarm system
hi i a m trying to install a clifford concept 100 and i am just wondering ,when trying to run the wire from the clifford unit to the factory door trigger wire do i use a butt connector and connect all three wires??
first of all, what year is your truck? if it is a first gen, then you should use the neg alarm trigger (usually green) and connect via t tap, splice with tape or solder to the orange lead on the under dash light. if it is a second gen with the dome override you need to use the green trigger (negative) and connect to the purple lead behind the headlight switch. hope this helps. any other questions please feel free to ask.
ORIGINAL: neeper74
What year and kind of truck are we working with???
Dang! Sure could have burned up something!!
Just use the wire coming of the pin switch in either kick panel. I don't remember the color code of the clifford but the wiring instruction should have which 1 ONE wire goes to neg. trigger. Opening any door throws a ground at all switches.
wexfordmike
03-18-2007 08:51 AM
