Bad shake at idle
Old Dec 14, 2009 | 08:15 PM
92s10Blzr's Avatar
92s10Blzr is on a distinguished road
Exclamation Bad shake at idle
a couple of days ago, I was driving in a hwy with the radio loud as usual until I realized a sudden loss of power and when I looked at the dash the blazer was overheating and when I turned off the radio I was able to hear the knocking like if the bearings spun over. I immediatly pulled over and the car shut off. I waited an hour for it to completely cool off while I was checking the oil. the oil was black and was lacking, so I walked over to the local gas station and bought a few cans, I poured in 2qts until it properly registered on the dip stick. so after it cooled down, i cranked it up and after a few slow cranks, it fired up and I quickly drove it to the gas station to fill it up with water and re-checked the oil. afterwards, everything seemed fine, no more knocking, or overheating issues, dont know where all the water went but it seems fine now. after a couple of days i started noticing a shake while at idle, at a stop sign, but if i put it in park or N, the shaking calms down, but once i put it into gear it shakes like a muscle car with a low cam with rough idle, but the wierd thing that while driving it on the street or hwy it seems fine, although it struggles a little at take off but then its fine. last night i briefly checked the engine and noticed that 2 of the 6 plug wires had cracks in the insulation, one had a deeper crack than the other, so i taped them up tight on the crack for the mean time as the local auto parts store was already closed. i'll be stopping by later to buy a new set of wires, im just wondering if its just the wires that are bad, or if I damaged the engine when it overheated.
BTW, its a 92 s10 with 4.3 TBI
thanks
Old Jan 8, 2010 | 02:15 AM
mk3Supra's Avatar
mk3Supra is on a distinguished road
bump, i would also like to see some help with this issue!
Old Jan 8, 2010 | 07:58 AM
I would run a compression check on the engine to make sure that you haven't warped or cracked a cylinder head or blown a head gasket. Overheating like that is never good and you probably severely shortened the life of the motor in the process.
While you are doing a compression check, I would do a full tune up consisting of plugs, wires, cap and rotor to get rid of those cracked wires and to get the rest of the ignition system up to snuff.
hillwilliam2
May 10, 2011 09:38 PM
mike8066
20
Apr 15, 2010 06:49 AM
JHZR2
Jun 13, 2009 12:37 PM
blazinloud
Jan 8, 2007 03:52 PM
blazinloud
Engine & Internal
Nov 2, 2006 09:20 PM
