bet you wont figure this one out.
Old Jun 18, 2009 | 10:36 PM
dannycam's Avatar
dannycam is an unknown quantity at this point
Default bet you wont figure this one out.
88 blazer 2.8l
the thing turns on just fine, and when i warm it up and turn the air on, and move the switch to full blast, the truck turns off. then it wont turn back on for a lloooong time, at least 30 minutes, and sometimes it wont turn on till the next day!
thoughts?
Old Jun 19, 2009 | 01:07 PM
CDJr's Avatar
CDJr is on a distinguished road
Sounds to me like you may have a loose lug nut
So youre saying the engine wont even turn over after you try to re-start it until the next day? Or it just wont start? When you turn the AC on, does the compressor begin to turn or do any dash lights come on before it dies?
Old Jun 19, 2009 | 01:22 PM
1998MSO's Avatar
1998MSO is on a distinguished road
Sounds like the battery /alternator isn't supplying enough power to keep the ignition running. Letting it sit probably gives the battery enough of a recharge to go again. I would diagnose the battery and alternator.
Old Jul 8, 2009 | 11:25 PM
dannycam's Avatar
thank you guys but i figured out the problem.
the truck had a wire running from the battery to the alternator that was spliced and touching the exhaust, causing a shortage. i didnt look hard enough. the wire was one that went to the junction block.
thanks for your help all of you!
chris015
Jul 14, 2015 01:26 PM
frankq
Dec 3, 2011 07:15 PM
Mike98Blazer
Sep 8, 2011 08:37 PM
user 1016
14
Mar 21, 2007 01:17 AM
z28chic
Oct 20, 2006 06:44 PM
