Big pothole = bad news
Old Jan 11, 2006 | 06:08 PM
  #21
93LT's Avatar
93LT is an unknown quantity at this point
Default RE: Big pothole = bad news
As far as the loose cam adjustment goes, that isn't uncommon considering what the torque specs are. Take in to account the low torque specs and the waxed frames and it makes for an easy adjustment alteration with as little as bumping a curb.
Old Jan 11, 2006 | 08:37 PM
  #22
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Thanks LT...you saved me a trip.
I've heard people talk about Blazers having tight steering anyway. Have you heard that as well and is it true?
Old Jan 12, 2006 | 12:26 AM
  #23
93LT's Avatar
The tightness of a gear box is a preference thing. If you think it is to tight in the steering, or don't like the way it steers now, you could let the alignment shop know and see if they would back off on the gear box a bit. Or it could be the camber is set a bit strong, or stronger than it used to be, but still within specs.
The first generation Blazers and S-10 pickups are not nearly as pciky, with regards to alignment specs, as the 2nd generation are. It's entirely possilbe your "Tight" steering could simply be too much camber, i.e. positive camber, that can give a quick feel to the steering as well. At the same time, the first gen blazers might still drive straight and wear the tires fine. The 2nd gen blazers, from my experience, require the alingments to be nearly centered in the specs to even drive straight much less provide even tire wear.
Old Jan 12, 2006 | 12:37 AM
  #24
m00nwater's Avatar
OK, totally off topic, but I just noticed your list of vehicles in your sig!!!!!! You have all those right now?!
Thanks for the info. So, for swartlkk's benefit, should he be able to do this on his Bravada as well?
Old Jan 12, 2006 | 12:44 AM
  #25
m00nwater's Avatar
Old Jan 12, 2006 | 12:56 AM
  #26
93LT's Avatar
ORIGINAL: m00nwater
Yeah, any GM gear box has adjustment in them. Actually, most Ford gear boxes do to. I hadn't paid close enough attention to Chrysler products, I tend to despise them
Old Jan 12, 2006 | 10:31 PM
  #27
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
ORIGINAL: m00nwater
In my opinion it is tigher. Not uncomfortable tight, but when i drive my mom's yukon, it feels noticably looser. I don't mind it, you get used to it. I think it makes it track straighter down the road, because it's less sensitive to bumps throwing it off course.
pj5454302
Oct 28, 2011 03:23 AM
mov4x4
Tires and Wheels
Jan 29, 2011 04:25 PM
kiwiblazer
Nov 8, 2009 08:16 AM
Zygoat
Nitrous, Super Chargers, & Turbos
13
Apr 8, 2008 01:46 AM
