Black soot coming from tail pipe
Old Feb 13, 2008 | 02:49 PM
Big E's Avatar
Big E is an unknown quantity at this point
Default Black soot coming from tail pipe
I have a 94 s10 blazer 4x4 and just recently black soot has been coming from the tail pipe. Also, I have noticed that the engine is idling rough when I am stopped at a light and the catalytic converter is smelling really bad. What could be my problem?
Old Feb 13, 2008 | 03:03 PM
Default RE: Black soot coming from tail pipe
Possibly an internal fuel leak that is causing the rough idle and over fueling while you are driving down the road. This would also make the exhaust smell worse. I would start with a fuel pressure test, specifically watching the leak down rate. You should only see around a 2-3PSI drop once you turn the key off and it should not drop from there. If it does, that indicates a leak somewhere in the fuel system. The CPI motors are notorious for having internal fuel leaks.
It is also possible that you catalytic converter is at fault or has become faulty due to the aforementioned problem (fuel leak). Do you hear any rattling while you are driving?
Again, I would start with a fuel pressure test and work from there.
Old Feb 13, 2008 | 03:31 PM
Big E's Avatar
Yeah the tail pipe seems to be rattling while sitting at a light but as far as driving down the road i don't hear a rattle.
Old Feb 13, 2008 | 03:34 PM
This could be the catalyst in the catalytic converter rattling around. If that is the case, then it sounds like your cat is to blame and things will only get worse.
Old Feb 13, 2008 | 06:35 PM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
unbolt the cat and start it up
Old Feb 14, 2008 | 08:45 PM
Scott's Avatar
Scott is an unknown quantity at this point
This is a classic Blazer problem. Please, someone correct me if I'm wrong, but doesn't the dumping of the fuel lead to the clogging of the EGR valve, and then the loss of braking power? I believe that's how a mechanic explained it to me years ago. Be prepared to stand on those brakes, Big E.
Old Feb 14, 2008 | 08:53 PM
The loss of brake power is a new one...
Old Feb 14, 2008 | 10:49 PM
94blueknight's Avatar
94blueknight is on a distinguished road
also u could check ur spark plugs too cuz if u have a fuel leak inside the plenum u would be able to see by this.
Straka88
Sep 23, 2011 05:35 PM
4x4willywill
Dec 27, 2007 11:18 PM
BlazerSS
Headers, Intake, & Exhaust
Apr 3, 2007 08:52 PM
kerander
Jan 18, 2007 01:21 PM
quontush
Jan 31, 2006 08:21 PM
