Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Tail pipe
Old Jan 30, 2006 | 02:23 AM
quontush's Avatar
quontush is an unknown quantity at this point
Default Tail pipe
i just got back from mudding and i messed up my tail pipe, any ideas of repalceing it? could i just put it out twards the side? anyhelp would be great
Old Jan 30, 2006 | 10:34 AM
Default RE: Tail pipe
When you say put it out towards the side, do you mean in front of the rear tire? If so, in many states, this is illegal. Many states require the exhaust to exit behind the rear tires and/or behind the passenger compartment and on a Blazer, the passenger compartment goes all the way back to the rear window.
Other than that, you could replace just the tail pipe. Use a hack saw or recip-saw (recip will be much faster and less tiring) clean up the edges with a file and slip on a replacement tailpipe from your favorite autoparts store. If it is only screwed up at the end, then maybe you could cut it off back a little bit (past the damage) and just install a new exhaust tip using the same method as above.
Old Jan 31, 2006 | 08:21 PM
quontush's Avatar
thanks for your help, yes i looked up some state laws and it said it cant be infront of the tire, so i am going to get a new tail pipe, a new muffler wiel im at it too i think
xwhyz1959
Dec 17, 2010 07:52 PM
big scott
55
Sep 10, 2010 12:58 PM
Big E
Feb 14, 2008 10:49 PM
4x4willywill
Dec 27, 2007 11:18 PM
BlazerSS
Apr 3, 2007 08:52 PM
