Blowing Fuses
Old Dec 2, 2006 | 02:20 PM
SDimeBlazerlady's Avatar
SDimeBlazerlady is an unknown quantity at this point
Default Blowing Fuses
[:@]Ok my 87 S10 Blaze is blowin heater/ac Fuses the 1st one i put in lasted 2 weeks it blew,2nd one 30 mins and no they blow as soon as i turn the switch on....HELP.....Could it be the fan motor killing the fuses? or something evil in my dash messed up? or is there something easy i can do? no other fuses are blowing... Thanks
Old Dec 2, 2006 | 02:32 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: Blowing Fuses
sounds like you have a wire rubbed and it is grounding out prematurely, causing the fuse to blow....
Old Dec 2, 2006 | 03:17 PM
Chevy Lover's Avatar
Disconnect the power wire at the heater motor, then turn on your switch. If the fuse still blows, the problem is probably in the switch or wiring. If the fuse doesn't blow, it's probably the heater blower motor.
Old Dec 2, 2006 | 06:40 PM
Thanks i found a new switch in the rear pouch put it in and seems to be working for the moment lol
Old Dec 2, 2006 | 10:53 PM
Nice to have a parts store in your back seat...lol
nineteensixtycaddy
Sep 12, 2010 08:54 PM
kaps
Jan 30, 2007 08:03 PM
XBlazer01
Jun 20, 2006 05:18 AM
WIKKID1
Jan 6, 2005 03:48 AM
WIKKID1
Dec 21, 2004 06:36 PM
