Brake bleeding!
Old Aug 20, 2012 | 10:06 PM
Sam Ford's Avatar
Sam Ford is on a distinguished road
Default Brake bleeding!
I have a 1994 Chevy S10 Blazer 4x4 with abs! Someone b4 i got it put a new master cylinder on it and didnt bleed the system! Im old school but i have to bleed these brakes so my question is do i bleed them the old way or do i need to do it on the abs unit itself?? TY
Old Aug 20, 2012 | 10:09 PM
Rottidog's Avatar
Old school to me is start at the PS rear, bleed them till clear fluid comes out. Then the DS rear, same thing. PS front & DS front both until clear fluid. The ABS (on my 2nd gen) works off a wheel speed sensor & I don't think it directly has anything to do with fluid, it's electrical. Now if the brake fluid is nasty, water contaminated that will affect braking & that could cause issues with the ABS.
Old Aug 20, 2012 | 10:24 PM
Sam Ford's Avatar
Ty my friend ill do that!!!
Old Aug 20, 2012 | 11:57 PM
richphotos's Avatar
What rottidog said, do it the old school way, the ABS is electrical. Then you should be good to go! good luck.
Old Aug 21, 2012 | 01:10 AM
50lb_cat's Avatar
+1, its only if the master has tons of air in it that you need the computer to do a bleed.
Old Aug 22, 2012 | 03:15 PM
Sam Ford's Avatar
Ty all so much!!!
portcqb
Mar 13, 2008 04:25 PM
jess1327
Mar 12, 2008 11:37 AM
Hanr3
Nov 23, 2007 08:26 PM
97Blazer15
Apr 26, 2007 07:21 PM
Dj7763
Mar 10, 2007 10:41 PM
