Brake system failure
Old Dec 5, 2007 | 10:52 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default RE: Brake system failure
WHy was it running when you did the calipers?
Did you change out the rear brakes too?
Old Dec 5, 2007 | 06:45 PM
thegr81's Avatar
I would check the calipers again make sure the slides are greased!! Then if it still does what its doing, then I would replace the proportioning valve!!
Old Dec 5, 2007 | 11:25 PM
Hanr3's Avatar
Engine off
Pump peddle three or four times.
Push peddle to floor and hold.
Open bleeder screw, let bleed for 1-2 seconds, close screw.
Release brake pedal and repeat until all air is out of hte system.
Start with the furthest brake, passengers rear, then drivers rear, passengers front, and finish with drivers front. In that order. Make sure you dont run out of brake fluid, and put the cap on while bleeding. If oyu leave it off all your fluid will spill over thet top and it WILL suck air. 2-3pump/bleed cylces and you should need to top off. Your get the routine down ont eh frist brake.
Joey1986Z
Jan 23, 2014 02:59 PM
teemac57
Jan 11, 2014 05:11 PM
cricketkoger
Jun 13, 2012 01:23 PM
cide
Nov 7, 2009 01:26 PM
93LT
Jun 21, 2006 07:38 AM
