A/C, Heat Control question
Old Oct 30, 2012 | 11:12 AM
Skitzoape's Avatar
Skitzoape is on a distinguished road
Default A/C, Heat Control question
i went out today to go to the store and my ac and heat controls to make the certain vents work is wacked out, i only get the dash and floor vents working. the slide for the temp works good, the blower speed switch works fine, just the slide that has the defrost, ac, and vent control isnt working right. anyone know why it would do that? doesnt seem like its getting any vaccuum cuz i dont hear any hissing once i turn it off after its running and in use
Old Oct 30, 2012 | 12:38 PM
ohsofly's Avatar
Yup, or the actuator door is jammed/broken... Get down on the pass floor and investigate for those issues or a vaccum line broken. Maybe lube the door too while in there. Easy fix.
Old Nov 3, 2012 | 10:58 AM
Skitzoape's Avatar
thanks man, ill look into it.
Old Nov 3, 2012 | 11:00 AM
Skitzoape's Avatar
are there alot of vacuum lines in the dash? so if there is a bad line, would it be hard to find?
Old Nov 3, 2012 | 01:32 PM
Skitzoape's Avatar
found the diaphram that works the vacuum that works the vent,ac,defrost controls is bad. i pulled it out and the center of it just fell out, i think that pretty much says broken lol.
now i have to try and get the temp cable back on without bending it!! yay for me!! -_-
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
kota04sxt
Dec 10, 2009 09:34 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
