a.c. question
Old May 4, 2010 | 01:56 PM
smokey94's Avatar
smokey94 is an unknown quantity at this point
Default a.c. question
94 s10 blazer the compressor will not kick in .can i put a toggle switch on and see if the switch is bad. if so which wires go together . thanks
Old May 4, 2010 | 06:04 PM
abig84's Avatar
Yea you can. I forgot which is positive. Just use a test light hooked up the positive side of the battery and find which one is the ground then run positive to the other side. I rigged up a air compressor with my ac compressor and its on a toggle. Could just be low on freon
Old May 4, 2010 | 07:58 PM
mr.vls's Avatar
Do you have freon? The low pressure switch would prevent the AC Clutch from kicking on. You can remove the plug from the low pressure switch and jumper it out. If the clutch kicks in you either have low freon or a bad switch. If nothing happens then you might have a faulty cluctch or a bad connection at the clutch. You can run a Pos/Neg wire directly to the clutch. It does not matter which is ground or not. The clutch is a coil that will energize either way.
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
98Ltblazer
Apr 11, 2010 11:34 PM
Numba1Sean
May 6, 2009 11:48 PM
redfan13
Mar 11, 2008 09:37 PM
Chadoo951
May 6, 2007 07:01 PM
