Can I live with the leak without damage
Old Jan 10, 2013 | 11:09 AM
bdegrand's Avatar
bdegrand is on a distinguished road
Default I'll drive it on the freeway to really check it
Thanks for your response. I will take it on the freeway and warm it up and then do the test to be more accurate.
Old Jan 10, 2013 | 08:20 PM
richphotos's Avatar
Originally Posted by bdegrand
Thanks for your responses, but now I am making sure the trans fluid is full. I checked it 'cold' after sitting in garage for a week and it was red all the way to the top of the dipstick. I then drove/ran it today for 5-10 minutes and while engine was running it stopped at the 'cold' line. What is the right way?
You check it cold, But the vehicle must be running, Go through all gears, and then check it.
Old Jan 10, 2013 | 09:09 PM
Straight out of the GM factory service manual for the 4L60E & 700R4 transmission:
"Operate the engine until the transmission fluid reaches operating temperature, (180F to 200F). Park the vehicle on a level surface. With your foot on the brake pedal, move the gear shift through each gear. Pause for about 3 seconds in each gear. Put gear shift in park. Remove the dipstick, wipe it off and reinstall it. Wait 3 seconds and remove the dipstick. Read both sides of the dipstick. Fluid level must be in the hot cross hatched area using the lowest level reading."
Edit: Transmission fluid capacity is 11 quarts: When the engine coolant reaches operating temperature, trans fluid temp may not have reached the same temperature, (takes a while to heat up 11 quarts). Drive the vehicle for ~20 minutes after the engine reaches operating temperature to make sure the trans fluid is up to operating temperature.
Old Jan 10, 2013 | 09:30 PM
richphotos's Avatar
Originally Posted by Captain Hook
Straight out of the GM factory service manual for the 4L60E transmission:
Touche.
Old Jan 11, 2013 | 09:22 AM
bdegrand's Avatar
Thanks again for the help...By the way, Capt Hook, I love the 'Warning shot' slogan!
Joey1986Z
Jun 23, 2014 11:09 AM
Patrick_Boyle
Aug 17, 2008 06:10 PM
FFJustin99Chevy
Sep 3, 2007 04:11 PM
Bauer318
Oct 24, 2006 05:39 AM
EkStreem G
Aug 29, 2006 05:20 PM
