center console measurement
Looking for a height measurement on the higher of the two center consoles offered in the S10. I know i have the short one, and it's approx 9.5 inches tall. I'm starting the design of my custom replacement console, and remember having the taller one in my last truck which was just about the right height for me.
Specifically looking for a measurement from the top of the arch in the back where it fits over the driveshaft hump to the top of the arm rest.
EDIT: This is specifically for the 1st gen trucks. Also, the width of the forward part of the Bravada console would be handy too. Thanks guys!
![Smile](https://blazerforum.com/forum/images/smilies/smile.gif)
Pretty sure its like 2 inches taller. I'll try to remember to measure mine tomorrow. I have both, swapped out the short one in my 87 for one out of a 94.
I have a 1994 s10 blazer. I have the
27 1/2 inches long
7 1/2 inches wide
11 1/2 inches tall
My measurements are for the box only, not from the hump
27 1/2 inches long
7 1/2 inches wide
11 1/2 inches tall
what are you refering to in the later part of that statement? are you talking about the tray that sits on the hump infront of the console?
if you are, they didn't only come in the Olds, we took one out of a 2WD Blazer that we grabbed the driveline out of for my brother's Dime build years ago.
i'll measure the height of the console tomorrow.
Sorry...I think it's still stuck in my mind that I was posting on one of the s-series forums...I remember a post in the first gen section about posting pics of the trucks, and out of 100 some odd posts, I think I counted a total of 4 or 5 first gen trucks. The rest were all 2nd gen trucks, and when someone questioned it, the response was basically "well they're still Blazers...WTF is the problem?"
In short, my bad :P
As for the Bravada console, it's my understanding that the consoles that came in the Bravadas were specific to those trucks. It's not just a separate tray, rather it's a completely different full console. As seen here: (not my truck, just something I pulled off of Google Images)
![](http://carphotos.cardomain.com/ride_images/1/3147/2441/7866220004_large.jpg)
That section in the front where the cupholders bows out, ends up being quite a bit wider than the rest of the console.
The part of the hump I was referring to was the very rear of the console where the arm rest is at, is arched to fit over the trans/driveshaft tunnel. At least on my current console, the driver's side of the console comes down about an inch farther than the passenger side, so that if you were to measure the height on the driver's side it would be a different dimension than the same on the passenger side. So I figured measuring from the top of the arch would make for the most consistent/accurate measurements.
In short, my bad :P
![Icon Razz](https://blazerforum.com/forum/images/smilies/icon_razz.gif)
that is a nice looking consloe, but kinda low (from the looks of it). why not just sit in the seat, and have someone measure up to where you would like the top to be, and then record that size? makes the most sense to me, since you're going for the "full custom" look.
That's pretty much what I did, although I measured myself. Problem is that I can't really relax my arm hanging in the air, lol. I'm just looking at other consoles that I know I've had experience with as reference points. Like I know from sitting in Bravadas, I can go a couple inches wider in the front than the OEM console, but without knowing how wide it is, I don't really know what my absolute dimensions should be around. I also know that the taller S10/Blazer console was pretty close to ideal for me, but again, without knowing the dimensions of that one...
Like I said, just all reference points. I suspect that I'll probably have to build up two or three of these consoles to get perfect dimensions anyways.
matthewp
04-04-2021 09:16 PM
