charging system problems
ok this is the problem
no charging at all, no alternator output
alternator checks out good, new alternator has same problem
all wires goin to battery are good, no high resistances
but there is a 2 pin connector on the alternator, that should have battery voltage with the key on, but it doesn't, and if i place a jumper wire from the battery to this connector it starts charging..... so i'm confused.... is there a fuse or relay controlling this circuit? or is it just wired into the ECM or what?
