check engine light
Old Sep 13, 2009 | 04:38 PM
classklown90's Avatar
classklown90 is on a distinguished road
i just changed my plugs,distributor cap, rotor and coil and it went away so try doing or getting a tune up and see if it disappears
Old Sep 14, 2009 | 12:38 AM
DubNblazer's Avatar
DubNblazer is on a distinguished road
thanks man, you rock
Old Sep 14, 2009 | 06:42 AM
lol np i try to help as much as I can since everyone else has helped me so much
Old Sep 14, 2009 | 02:17 PM
4x4VegasDan's Avatar
4x4VegasDan is on a distinguished road
any idea where I can get the codes for an 84 s-10 blazer? Troublecodes.net goes from 82-83 then right to 86. Also, can i use the paper clip method?
Old Sep 14, 2009 | 02:47 PM
bandidolenny's Avatar
Yes, you can use the paper clip method.
When I describe these older computer vehicles as "archaic", I am describing the vague and ambiguous conclusions of the codes.
For example... if you get an oxygen sensor code, don't go changing the oxygen sensor... figure out what's causing the code to be thrown in the first place... like a rich running engine or a vacuum leak.
Old Sep 14, 2009 | 04:41 PM
Alright. Thank you sir. I will check it out today.
Old Nov 30, 2009 | 08:01 PM
Where is the 12 pin dlc located exactly? I located one on the passanger side but it only has 4 pins.
Old Nov 30, 2009 | 11:25 PM
Under the driver side of the dash.
Old Nov 30, 2009 | 11:55 PM
Thank you kindly.
Old Jan 17, 2011 | 12:21 AM
tbcfreerider's Avatar
tbcfreerider is on a distinguished road
Im trying the paperclip and get nothing to flash at all?!?!?! 93 s10 blazer
zombiewoof
Feb 1, 2009 12:06 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
