code 35
Old Feb 15, 2010 | 02:31 PM
drtyblnd's Avatar
drtyblnd is an unknown quantity at this point
Cool code 35
any one ever heard of a code 35
i bought this 93 blazer Lt 4.3 vortech for next to nothing it had a bad motor so i found a donar blazer and swaped it out
it has the digital dash but the dash sometimes works and somtimes doesnt
everthing that works works real slow like the wipers windows ect. smells like it runs a little rich. blue smoke comes out the exhaust. brakes kinda hard to push.
all the codes im pulling are 22, 35?, 43, i've swaped some of the spendy parts with working ones like egr & map i put in new fuel pump plugs wires cap and rotor thermostate therm sending unit
these codes will not go away any one have any idea what else could be wrong any info would be helpfull thankyou
Old Feb 15, 2010 | 06:14 PM
rriddle3's Avatar
is your friend. It turned up quite a few hits, including this page.
Old Feb 15, 2010 | 06:32 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Gimpy is your friend too. I cheated and looked in the book. It also tells you how to troubleshoot although the knock sensor is the only one you don't need a scan tool for. As for everything running real slow, it sounds like you don't have good grounds between the engine and body/chassis.
22 Throttle Position Sensor Circuit Low (Signal Voltage Low)
35 Idle Air Control (IAC) Error
43 Knock Sensor Circuit
Old Feb 15, 2010 | 06:49 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
my windshield wipers slowed down when i had a bad alternatior, new alternator and no problems
Old Feb 16, 2010 | 07:22 PM
drtyblnd's Avatar
thanks guys i looked over all the ground wires really good and guess what low and behold the groung wire from the bat. was the culpret it was broken at the terminal i put nw terms. on grounded everthing really well and BAM!!!! no worries. and again thanks alot for your replies. as always blazer forum rules.
92s10Blzr
Dec 7, 2009 03:12 PM
nitro7
Dec 1, 2009 06:27 PM
98blazr
44
Aug 21, 2009 01:17 AM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
