Coolant temp. guage not working
Old Nov 26, 2006 | 11:08 PM
myronhntr80's Avatar
myronhntr80 is an unknown quantity at this point
Default Coolant temp. guage not working
I have replaced coolant temp sensor in the front of the intake manifold and the temp sender in the passenger side head but the guage still doesn't work. I haven't checked continuity on dark green wire that runs to temp sender in the head yet. One thing I thought was weird is that the temp sender is a two prong sender but their is only one wire in the connector. Is that normal?
Old Nov 26, 2006 | 11:17 PM
Chevy Lover's Avatar
Default RE: Coolant temp. guage not working
I thought the temperature sensor has 2 terminals and the temperatur sender only has one. I could be wrong but then again, the person who sold you the part could be wrong. What about the old sender, did it only have one terminal?
Old Nov 26, 2006 | 11:23 PM
I sold myself the part. I have worked @ Schuck's Auto Supply for almost six years. old and new parts are Identical and direct cross over from OE #'s on original. The plug in connector has a specific shape to it so that it won't fit into other sensors. I also wrapped the threads of both sensors in teflon tape to provide a good seal. I am not sure that I should have done that or used some sensor safe permatex or just thread sealant....
Old Nov 26, 2006 | 11:33 PM
Good thing I didn't call the partsman names....lol
I suppose the teflon tape could cause a problem, if the sensor uses the head for a ground?
Old Nov 27, 2006 | 01:09 AM
that is exactly what I was thinking possibly not getting ground. But on the other hand the original sender did NOT have teflon tape. But it could have still been a bad sender.
And don't get me wrong, I may sell parts but I am still no master mechanic by any means. I would say I have decent general knowledge on most systems, still with LOTS to learn.
Old Nov 27, 2006 | 02:57 AM
20Blazer00's Avatar
I would remove the teflon tape, the GM Service information states that you should not use teflon tape or any other type of material since the threads are designed to be self sealing so that the part is properly grounded.
Old Nov 27, 2006 | 03:25 AM
I'll take the tape off and see what happens. I am also going to check continuity on that first couple feet of wire attached to the sender. We shall see.
Old Mar 6, 2008 | 07:58 PM
Mulisha's Avatar
Mulisha is an unknown quantity at this point
Did anything come back?
drummerdude
Nov 7, 2011 07:35 PM
Schills
Sep 16, 2010 09:15 AM
David Hineline
Aug 20, 2010 10:07 PM
bertrenolds
Dec 19, 2008 07:45 PM
DaddyCop03
May 11, 2008 09:07 PM
