Crazy tailgate squeak!
Old Dec 8, 2014 | 10:30 AM
bestos's Avatar
bestos is on a distinguished road
Default Crazy tailgate squeak!
Just joined. 1993 s15 jimmy 4.3L. 132k miles. Just got a few things sorted out with water pump and coolant sensor (would start or run after it went bad).
The worst thing about this new is the sporadic / constant squeaking from the tire carrier / tailgate assembly. I think the bushing where the tire carrier Latches to the assembly on the tailgate is cracked and worn thin. That is the only place i can see where it would squeak. I did spray a little silicone on that location and it helped quiet it down for a day, so i think that is the problem.
Where in the heck do i get a new bushing to go in there or is there another solution. even LMC has nothing regarding the tire carrier that i can find. anyone have any suggestions? my search was not effective at all
Thanks in advance
1993 s15 jimmy 4 door
1995 YJ and 1991 YJ
1995 240sx
Old Dec 9, 2014 | 05:55 AM
bestos's Avatar
update, after further review of tire carrier latch/striker assembly and seeing a picture on ebay of one for sale, the Striker that the tire carrier latches to, is split and worn thin. this looks to allow the carrier to droop a little and the upper bar sags a bit, causing the upper bar to rub on the metal. a local dealer, helped me find another dealer that has the whole assembly for 40 bucks plus ship. will update when received and installed
Old Dec 10, 2014 | 02:43 PM
richphotos's Avatar
Dont forget to do the bushings on the actual hinge of the arm while you are at it, they are known to cause that squeak.
Old Dec 11, 2014 | 05:25 AM
bestos's Avatar
Yes sir. New latch assembly on, it squeezed for 3 min, then was silent. My guy at work, said the nylon striker was broke for a reason, and told me to change hinge bushings. Working on acquiring those, thanks a lot.
94s10blazin
Sep 24, 2018 10:38 AM
WickedBlazer
Sep 12, 2012 03:14 AM
thrash902
Sep 15, 2010 10:52 PM
gclark1
Dec 6, 2007 02:53 AM
