ANY MASTER TECHS HELP!!!!!
Old Apr 6, 2007 | 12:03 AM
peegh's Avatar
peegh is an unknown quantity at this point
Default ANY MASTER TECHS HELP!!!!!
I have a 95 chevy blazer that is driving me crazy. It started last year as a miss and has turned into a nightmare. First I tried new plugs and wires. no luck, so here come the list of what has been done between different mechanics and even a chevy dealership.
cap
button
distributor
coil
the spider was leaking so it was replaced
upper and lower intake
map sensor
air valve
computer
fuel pump
ignition module
engine was smoked and no vacuum leaks found.
compression tested on all cylinders 125+
valves working correctly
the engine misses very bad when cold and as it warms up it lessens. never goes away. All plugs dry when removed. code is for cylinder one misfire. and 02 sensor efficiency below threshold. I am at my wits end with this. Any suggestions???
Old Apr 6, 2007 | 12:41 AM
white95blazer's Avatar
white95blazer is an unknown quantity at this point
Default RE: ANY MASTER TECHS HELP!!!!!
I have a 95 to and it wasmissing like crazy now its every so often while driving. I'v done plugs twice, wires, cap and button, o2 sensors, and I was told to try cleaning some kinda sensor on the front of the motor I don't know what it was called but it help alittle also.
Old Apr 6, 2007 | 05:21 AM
Chevy Lover's Avatar
It's possible that you have a valve guide problem. I have seen a missfire condition on some blazers and astro vans where the valve guides were worn and causing a missfire.
The repair is not cheap as the heads need to go to a machine shop for repair.
Old Apr 6, 2007 | 08:58 AM
drperry's Avatar
I'm assuming by button you mean rotor? if not, you should look into that... fuel filter...
Get your o2 sensors tested, and maybe your cat. as well... I can't remember if your year has a Crank Position Sensor, but if it does, get that looked at too...
Old Apr 6, 2007 | 07:47 PM
Everyone keeps saying rotor button, what part is actually the rotor?
Old Apr 13, 2007 | 12:39 AM
peegh's Avatar
Sorry I went on vacation so I haven't been able to reply. The o2 sensors were also replaced as well as the crank sensor. Not sure about the valve guides I know that the valve covers were off to check for valve movement but the guides themselves I don't know. The good thing is that while on vacation I found a 2000 chevy blazer/trailblazer with 88,000 miles for sell and I bought it. So at least I have a ride in the meantime
Old Apr 16, 2007 | 04:38 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
ORIGINAL: 1badblazer
Did you happen to bleed the brakes recently???
I used to have a 95 blazer until I bought a real car. keep up the hard work on the peace
Peace
This isn't that kind of forum guy....so keep walkin'
Back to something constructive.....have you checked the ground straps on the engine.....it's just a thought, but you should make sure that all the ground cables are clean and tight.
battery to engine
engine to chassis
battery to body
It doesn't ever hurt to add some redundant ground wires either, I would put one from body to chassis as well.
Old Apr 21, 2007 | 03:34 PM
peegh's Avatar
I'm wondering if the timing gears and chain are out of whack. It's been very frustrating to say the least
Old Apr 22, 2007 | 02:32 AM
I'm still thinking that the valves guides are the problem but that's not a cheap repair and the only way you'll know for sure is to take the heads off and into a machine shop.
Old Apr 22, 2007 | 11:47 AM
erauto's Avatar
erauto is an unknown quantity at this point
iam thinking that you might have a bad cat converter, you can check this with a pressure trasnducer and a vantage pro or modis. compare both banks, shouldnt have more that 12psi if 30 your cat is plugged. either way you should remove it, install a o2 simulator, and problems gone.
94s10blazin
Aug 10, 2013 01:00 PM
Ryanmatt135
Jan 29, 2011 10:48 AM
rastoma
Jan 17, 2011 06:25 PM
Dakota_Don
Apr 26, 2010 12:25 PM
p_j_robertson
Aug 12, 2006 05:21 PM
