Digital Odometer Issues
Old Sep 8, 2013 | 01:59 PM
TheRemedy's Avatar
TheRemedy is an unknown quantity at this point
Default Digital Odometer Issues
My family has had my 89 S10, 4.3 since it was brand new. I would guess since about 92ish the odometer has had problems. It is the digital dash, and the odometer flicks on and off, and at times just shows error. I know while it was under warranty something was replaced and it worked for a while, but soon went back to the same errors. As of now, I haven't see the correct mileage for quite a few months and would like to know what my MPG is. On certain days when the odometer does work, the mileage is accurately displayed, so it is stored somewhere correctly.
Does anyone have any tips for getting this fixed, is there any add on odometer that I could plug in to take readings?
Old Sep 8, 2013 | 02:06 PM
xgiovannix12's Avatar
typical cluster that needs to be repaired Do a search there is many threads covering it.
Old Sep 8, 2013 | 04:59 PM
TheRemedy's Avatar
I suppose there isn't any way to get the current mileage reading off of the cluster though?
Old Sep 8, 2013 | 05:04 PM
Not that I know of.
Old Sep 15, 2013 | 04:17 AM
ohsofly's Avatar
You can buy a new cluster for 200 bucks from digitaldashsolutions.com
I have one and it works perfectly. You have to send the old core back though.
Old Sep 15, 2013 | 09:53 PM
richphotos's Avatar
Bad solder joints, take the cluster out, find out which solder joints are for the odometer, and re-solder them, should fix the problem. Especially since everything else is working.
MikeMSU
Jan 4, 2015 04:05 PM
Blaussie
Jul 11, 2013 08:08 AM
shibbershabber
Feb 22, 2010 10:07 PM
Bl4z3r
Feb 10, 2009 08:39 PM
Jeff_Cullen
Mar 21, 2006 08:52 PM
