Do I need more than Coils..?
My '85 S10 Blazer came with cut coils to lower it..(ouch)..do I need to change to lowered spindles too..or just proper lowered coils??Front end is worn out too so everything will be apart at one point to restore the front end..thanks
It all depends how much you want to lower it. If you only want to go an inch or two then coils will be just fine. But lower will require spindles also. When I had my '92 S10 I was going to lower it 2 inches and use spindles just so I would not lose the ride it had, because lowered springs will cause a slightly harsher ride. Korey
May One
Engine & Internal
06-20-2012 03:27 AM
fallen4her02
04-24-2011 09:37 AM
Blaze the S10 4x4 Blazer
04-20-2011 09:02 PM
