Don't Know what to do with this problem
Old 08-14-2009 | 12:59 PM
Originally Posted by AJBert
Just a heads up, the circuit boards are known for failing due to cracks developing in the soldered connections causing all kinds of havoc. A new circuit board only runs about $20 and is very easy to replace.
Or you could resolder the connections as shown in the thread below:
Fix for cold solders in the Wiper Motor
Old 08-14-2009 | 06:10 PM
tony991's Avatar
tony991 is on a distinguished road
ok... i pulled the wiper motor off today.. and on mine, you can't take the cover off.. its rivited on.. is there anything else i can do.. cause i really dont want to have to buy a new motor if i don't have to...
Old 08-14-2009 | 07:54 PM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
Drill out the rivets and pull the cover off. Use bolts and nuts to reattatch.
Old 08-16-2009 | 07:50 AM
tony991's Avatar
ok ill give that try..
Old 08-17-2009 | 11:45 AM
tony991's Avatar
i drilled out the rivits on the wiper moter... and there is no circuit board at all...
Old 08-17-2009 | 12:06 PM
mr.vls's Avatar
mr.vls will become famous soon enough
If you do not have the delay system I am not sure if there is a circuit board or not. The fault isolation I listed in a previous post had two different approaches. One with delay and one without.
Old 08-17-2009 | 12:11 PM
tony991's Avatar
so.. what do you think i should try now??
Old 08-17-2009 | 12:59 PM
tony991's Avatar
could the circuit board be located somewhere else?
Old 08-17-2009 | 01:35 PM
mr.vls's Avatar
base wiper system the following applies: With Ignition Switch On, Wiper Switch in Off position, remove connector from wiper terminal, connect jumper from terminal No. 2 and No. 3 and 12 volt source to terminal 4. if wiper parks replace column switch, If Wiper still runs repair wiper motor (Check Park Switch Actuator and Brush Holder Assy)
88s10Blazer
Lifting Tech
34
10-17-2010 02:50 PM
BlazerLT2001
06-23-2010 09:51 PM
havrelm1
07-24-2008 09:26 PM
cvcmama22
04-07-2008 06:41 AM
grubdub761
10-18-2007 02:48 PM
Quick Reply: Don't Know what to do with this problem
