driver side
Old Dec 8, 2006 | 09:27 PM
FImports's Avatar
FImports is an unknown quantity at this point
Default driver side
alarm kit i have will lock all three doors except mine(drivers side)anyone have a clue
Old Dec 8, 2006 | 09:38 PM
20Blazer00's Avatar
Default RE: driver side
Check the installation manual for hints about this problem. If doors locked before then you should look over the installation instructions for any OH OH NOTES. If that does not help check with the company that makes the kit either online or where you bought the kit from. If they offer installation maybe the are willing to help with the problem.
Old Dec 8, 2006 | 09:54 PM
FImports's Avatar
ALARM IS GREAT.i think there's something wrong with the drivers side lock.is there like a hanger type thing that locks the door
Old Dec 8, 2006 | 09:59 PM
20Blazer00's Avatar
There are rods that attach to the door handles and the lock so you can open the doors. To get at those then you will have to remove the door panel on the inside... There are 3 screws that hold it into place along the arm rest and then a lot of spring clips arount the outside edge. Then you can lift up and pull the panel off from there. THERE IS A SCREW IN THE MIDDLE THAT IS HARD TO SEE under the arm rest pull handle...this panel is not cheap to replace if you break it....
Old Dec 8, 2006 | 10:06 PM
FImports's Avatar
thanks for your help
mamawolf70
Apr 10, 2020 10:44 AM
Wexinlo
Apr 6, 2011 11:35 PM
rlarge2000
Mar 14, 2009 12:45 PM
TheDesertFox
Oct 9, 2006 08:14 PM
Walleye
Feb 18, 2006 04:14 PM
