driver side
Check the installation manual for hints about this problem. If doors locked before then you should look over the installation instructions for any OH OH NOTES. If that does not help check with the company that makes the kit either online or where you bought the kit from. If they offer installation maybe the are willing to help with the problem.
There are rods that attach to the door handles and the lock so you can open the doors. To get at those then you will have to remove the door panel on the inside... There are 3 screws that hold it into place along the arm rest and then a lot of spring clips arount the outside edge. Then you can lift up and pull the panel off from there. THERE IS A SCREW IN THE MIDDLE THAT IS HARD TO SEE under the arm rest pull handle...this panel is not cheap to replace if you break it....
mamawolf70
Apr 10, 2020 10:44 AM
Wexinlo
Apr 6, 2011 11:35 PM
