driver side brake caliper sticking.
Old Nov 17, 2012 | 07:11 AM
chris015's Avatar
Default driver side brake caliper sticking.
Ive had this issue for a little while. I thought i fixed it. Last night i raised the front end to check for play and noticed i had more drag on the driver side then the passenger side. a few months ago i replaced
both calipers
both front brake hoses
bled system
I greased the slides etc correctly. its still doing it. I'm not sure now what to do. Im wondering if my proportioning valve is sticking. i dont have abs.
Old Nov 17, 2012 | 03:59 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
more drag or is it locking up? Does it still rotate at all if you spin it?
Old Nov 17, 2012 | 06:33 PM
chris015's Avatar
its not locking up,you know how when you adjust the drums you adjust till it has a bit of drag? its doing something sorta like that. its not spinning freely like the other side. last time i changed pads the inner was worse then the outter.
Old Nov 17, 2012 | 07:06 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
I have had this same issue myself, I can't keep changing the same stuff all the time. Can someone figure this out...please......
Old Nov 17, 2012 | 07:08 PM
chris015's Avatar
im about ready to delete the "rawl" system it has and put in a earlier 85" proportioning valve.
mamawolf70
Apr 10, 2020 10:44 AM
RyanLoerch
Oct 25, 2011 03:26 AM
Irishdrums
May 31, 2011 02:47 AM
Wexinlo
Apr 6, 2011 11:35 PM
Schmev
Dec 30, 2007 01:34 PM
