engine don't start (maybe fuses)
Old Jan 1, 2011 | 02:56 PM
Christobal's Avatar
Christobal is on a distinguished road
Default engine don't start (maybe fuses)
Hello, I'm christophe from France.
I'll try to explain in english my problem.
This morning I finish to install the new heater core on my 92 blazer S10.
When I put back the autoradio and tried to plug the antenna... I put it in a wrong hole... and touch a wire inside the autoradio.
I heard a "clac" who makes me think... "a fuse"!
In fact, the radio fuse was dead.
I change it and checked all other fuses.
But until that, the chevy absolutely refuse to start.
Starter work, engine turn... but don't start.
Is there a fuse somewhere I don't see?
Is it possible to break the ECU or ECM??
Does some one have an idea to help?
thanks very much (and sorry for my english)
Old Jan 2, 2011 | 09:12 AM
Christobal's Avatar
help
Old Jan 2, 2011 | 09:26 AM
Did you double and triple check all connections that were disconnected during the heater core removal/install? Your ECU is in that area..
Old Jan 2, 2011 | 11:00 AM
Christobal's Avatar
Thanks for your help...
I've not disconnected anything except the radio...
But I will check on the ecm if something is not disconnected.
thanks again.
I've found something...
I put some fuel directly in the injection body... and the chevy start.
So, it is not the ignition.
Maybe the fuel pump or the ecm??
could you help me to determinate where is exactly the fuel pump relay on my 1992 S10??
I have relay under the hood, relay in the fuse box...
If my problem doesn't come from the relay or fuel pump... where looking for??
thanks and sorry to insist
Last edited by swartlkk; Jan 2, 2011 at 03:05 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Jan 2, 2011 | 04:07 PM
If fuel into the intake allows it to start, you definitely have a fuel delivery problem.
The fuel pump relay is located on the firewall. I believe it is located near the brake booster and should share a bracket with the A/C relay (if equiped) with the fuel pump relay being the one closest to the left side of the vehicle.
Old Jan 5, 2011 | 10:55 AM
Christobal's Avatar
Hi there,
Just some news...
Yesterday morning, I tried again to start the blazer... and he started.
I don't understand anything but...
Thanks a lot to those who helped.
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
blazinjay83
Aug 4, 2010 06:54 PM
Luvthyblazer
Apr 19, 2010 07:59 PM
USMaverick101
Nov 17, 2006 04:06 PM
