engine help
engine help
i have recieved a 1985 2.8 s-10 engine, and i am going to be doing a overhaul/rebuild of the engine and what i would like to do is put fuel rials(fuel injection) on the engine....is this possible? and if so what will i have to do?
RE: engine help
So you'd like to go MPI and not TBI correct? It's going to be fun, I can assure you that. Your 2.8L now is TBI is it not? You probably can weld injector bungs onto your current intake. You would then probably have to have someone fab up some fuel rails.
Next problem you'll run into is a higher output fuel pump. Your TBI engine doesn't require the pressures that a MPI system requires. And I cannot remember if the old TBI 2.8L was a returnless fuel system or not...
RE: engine help
yeah, your right so far...but i thought someone is selling the rails to convert from carb to fuel injection
RE: engine help
It is quite possible... I had a feedback carb'd 2.8L in an '85 S10 pickup, but beyond working on that dog, I don't have a bunch of experience with the 2.8L except in passenger vehicles that already had MPI.
RE: engine help
there was 1 posting before that i will have to find where he was doing the same thing and he said that all you really have to do is install a fuel filter in the gas tank
RE: engine help
ORIGINAL: iceman1987
Your current TBI system uses batch fired injectors in a carb style body, the MPI system would fire the injectors as needed and would require a different computer.
RE: engine help
Correct me if I'm wrong, but aren't most of the MPI intakes for the 2.8L are on passenger vehicles with DIS?
RE: engine help
the air intake is on the driver side...is that what you are talkin bout...is not than what is DIS....?
RE: engine help
DIS == Distributorless Ignition System
And yes, most of the transverse mount engines (FWD) do have the TB positioned at the back of the engine.
RE: engine help
Fuel injection didn't come to the S-Series until 1986...
'85 is pure carb baby!
an MPFI setup is going to be a pretty nasty job, because you'll have to drill injector holes for each cylinder. You'll need heads at the very least from an MPFI setup, and an electric fuel pump...
It's not worth the hassle trying to MPFI the carbed 2.8.
Steal an MPFI 2.8 from an F-Body, and you will be MUCH better off...
It's still a direct drop in... And you'll only need the fuel pump, and possibly gas tank...
N.alaska_blazer
02-23-2009 01:31 PM
Tony H
12-14-2008 02:04 AM
loppy crimp
09-11-2008 08:31 PM
DBlaser_ca
08-02-2007 04:44 PM
