Engine Stalling when trying to accellerate?
Old May 18, 2008 | 09:05 AM
Always Something's Avatar
Always Something is an unknown quantity at this point
Default Engine Stalling when trying to accellerate?
Hi Guys,
I have an 88 S10 Balazer with the 4.3 TBI 4x4. I have just installed a used low miles engine with all new stuff. It starts fine, a little high rpm for a minute, but then perfect. The issue is when I try to accellerate. The engine cuts out and stalls. It sounds like it has died but it is still running. It also does it in Park if you try to step on it and rev it up too fast. Can anyone tell me what to check first? Thanks.
Old Jun 2, 2008 | 12:00 AM
dbleon's Avatar
dbleon is an unknown quantity at this point
Default RE: Engine Stalling when trying to accellerate?
I have the same EXACT issue... can anyone provide some insight?
Old Jun 20, 2008 | 08:58 PM
The Slacker's Avatar
The Slacker is an unknown quantity at this point
Check fuel pressure?
Old Jun 20, 2008 | 09:09 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
First question for what reason did you change the motor??? did it do that b4? have you checked the timing? maybe theres a vacuum line off somewhere on the throttle body... just sum tips maybe they`ll help..makew sure you didnt crimp a fuel line putting the new motor in it.....
Old Jun 26, 2008 | 10:03 AM
Sunshine Coaster's Avatar
Sunshine Coaster is an unknown quantity at this point
When you swapped motors did the exhaust take any beating during the job? ie: did you drop it down on the floor or shock it in any way? Check your catalitic converter, if it's broken up the little pieces can clump together by exhaust pressure and act like check valves...the back pressure from this will stall out the motor. I had the same symptoms and it was the CAT...it wasn't even broken up that bad, just a few pieces rattling around in it. The CAT is really fragile, I took my old one apart and you could crumble the pieces in your hand.
wcook369
Dec 21, 2010 02:54 PM
PaulO2288
Nov 1, 2010 06:10 PM
murray32x
Sep 23, 2010 03:11 PM
matrixgk17
Jun 23, 2010 02:27 PM
WVblazer
Jan 26, 2008 05:34 PM
