engine stalling....
Old Sep 22, 2010 | 06:32 PM
murray32x's Avatar
murray32x is on a distinguished road
Default engine stalling....
well i just bought this 95 blazer and all seemed well until the fuel pump went bad. so i had a new one installed and it ran great for a day or so but now its stallling again. the engine does not seem like its recieving fuel. also when pressure builds up in the tank gas leaks out of the hose by the gas cap. the truck ran fine with the gas cap off though? could it be another bad pump even though its new? or maybe an electrical problem? or a vent line issue?
please help
Old Sep 23, 2010 | 02:47 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
To see if it is the fuel pump first check if the fuel pump is even running(you should be able to hear it, a higher pitched wine almost but not extremely loud) Next check how much fuel PSI you have at the engine. There are service ports on the feul line in the engine compartment that you can screw on a fuel psi gauge to. For the other problem, that sounds like an emissions problem, possibly a plugged charcoal canister or vent lines to it?
Old Sep 23, 2010 | 02:57 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
has the fuel filter been changed since the pump? and what brand pump was installed? The fuel filter should be in the frame on the drivers side under the area of the drivers seat...
Old Sep 23, 2010 | 03:11 PM
murray32x's Avatar
the mechanic whos a family friend said that he replaced the filter with the pump. he just called me today to tell me he replaced the vacumn lines on it as well. but he said that if it doesnt solve the issue of it stalling it could either be the fuel regulator or the fuel injector? that sound about right?
wcook369
Dec 21, 2010 02:54 PM
jsleeper81
Sep 28, 2010 04:27 PM
matrixgk17
Jun 23, 2010 02:27 PM
Always Something
Jun 26, 2008 10:03 AM
WVblazer
Jan 26, 2008 05:34 PM
