Factory Plug Gap on Beefed up 4.3?
Old Sep 26, 2012 | 12:28 PM
NCSurvival's Avatar
NCSurvival is on a distinguished road
Default Factory Plug Gap on Beefed up 4.3?
Ok, so my question is, when you change the engine displacement, does the plug gap change at all? I have a 4.3 TBI bored over .060, running flattop 350 pistons, mild Comp cam, MSD ignition system and distributor. ECM is chipped with Edelbrock chip, and running Venom injectors. If I did my math correctly, the engine is now nearly a 4.5L.
Old Sep 26, 2012 | 07:21 PM
Blazin_Jason's Avatar
Most people who upgrade the ignition coil and components, tend to like a slightly larger gap. 0.040-.045 if I remember right.
Old Sep 27, 2012 | 06:01 PM
NCSurvival's Avatar
ThanksI will try that on the next plug change.
Old Sep 27, 2012 | 06:53 PM
chris015's Avatar
My plugs are gapped around 40 from normal wear. Noticed a bit of a mid end improvement. compared to factory gap, but Ive got alot of mods done. They do look like they are running a bit hot though. I need to replace em anyways.
Old Sep 28, 2012 | 09:12 AM
NCSurvival's Avatar
My engine was designed to throw all the torque in the mid and low ranges. Anyhow, shouldn't hurt to try 40 to start, see what kind of changes I get, and go from there.
Old Sep 28, 2012 | 11:17 AM
chris015's Avatar
If you wanna play with that #3 plug more then once lol gap em around 45. Drive it and then gap it at 40 and try again.
Old Sep 28, 2012 | 04:58 PM
ohsofly's Avatar
Number 3 is a breeze if you have a meter long extention. I do mine from the wheelwell amd its a snap.
Old Sep 28, 2012 | 07:05 PM
chris015's Avatar
ive actually got a tool for #3. its a t bone looking extension with a knuckle and a 5/8th socket attached to it. works great
ijamm
Jul 17, 2022 09:45 PM
dbleon
Dec 29, 2007 06:04 PM
havrelm1
Nov 26, 2007 10:53 AM
sincbr
May 17, 2007 01:19 PM
USMaverick101
Sep 28, 2006 12:42 AM
