flushed heater core, still no heat
Old Jan 26, 2007 | 02:06 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Default RE: flushed heater core, still no heat
I had a simular issue with NO heat. What it turned out to be was a control valve inside the truck for the heat/AC systemthat was not opening to allow the blower to blow threw the heater core. So I had no heat. Both heater core hoses where hot to the touch, so I knew the coolent was passing threw the heater core. Fixed the control valve and wow got heat now.
Old Jan 26, 2007 | 09:57 PM
thegr81's Avatar
yea change the control valve and if that doesn't work then ur problem might be something i ran into check your oil is it milky if it is then u have got blow by in your intake manifold and you will have to replace your gaskets with felpro pinto gaskets. just wanted to cover all basis.
Old Jan 28, 2007 | 07:17 PM
mikeemo's Avatar
mikeemo is an unknown quantity at this point
A friend of mine with a 96 had a problem like that after he flushed his cooling system. I think it had something to do with air in the lines. He said the system had to be bled. I mentioned that I planned to change the thermostat in my truck and he told me that I might have to do that when Im finished. Could you be having the same problem ??
Katmandu
Jan 14, 2010 02:10 AM
bmxican1023
Dec 15, 2009 02:18 PM
topgunfan
Jun 8, 2009 10:14 AM
mudd4
Aug 23, 2008 08:46 PM
2blzers
Dec 16, 2007 10:14 AM
