Flywheel cracked?
Old Oct 4, 2014 | 08:33 PM
NCSurvival's Avatar
NCSurvival is on a distinguished road
Default Flywheel cracked?
I searched the forums, but have not found a solid answer because the thread is closed with no solution? I found this video on YouTube and this is EXACTLY what my truck is doing now. Sounds like the valve train, and you would swear by it, but when you get down to the torque converter......
Any ideas? Cracked flywheel?
Old Oct 5, 2014 | 09:31 AM
rexazz2's Avatar
I had it happen on a 305
Starter began giving me issues with engagement
The flywheel had cracked all the way around the crank bolts and then started spidering out towards the teeth
If you unbolt the torque converter it may move away from the flywheel enough to get a better look or you may be able to move the outer edge of the ring gear
Old Oct 5, 2014 | 09:33 AM
rexazz2's Avatar
looks like you already replaced the starter
Old Oct 5, 2014 | 09:38 AM
rexazz2's Avatar
by reading the comments on this looks like the guys bolts were missing or loose
Old Oct 5, 2014 | 10:55 AM
newguy's Avatar
Not even connected
Old Oct 5, 2014 | 02:19 PM
NCSurvival's Avatar
This isn't my truck. It's a video someone posted on YouTube that has the EXACT same problem as I have. But I have a heavy duty starter that works fine.
Old Oct 5, 2014 | 02:44 PM
rexazz2's Avatar
I had no noise
it was the starter issue that brought forward the issue
Old Oct 5, 2014 | 02:46 PM
rexazz2's Avatar
Originally Posted by newguy
Not even connected
not the torque converter , the crank bolts
looks like that one had a fresh motor
Old Oct 8, 2014 | 09:44 PM
NCSurvival's Avatar
Turns out a valve was very loose. And the noise carried down the back of the motor to the torque converter. She’s sounding awesome again.
LowLife
Apr 14, 2010 05:27 PM
thisclan3
Jun 30, 2009 09:00 AM
jonesjamesw
Mar 28, 2008 06:33 PM
tom1337
Nov 10, 2007 12:18 PM
mars004
Jan 22, 2007 10:00 AM
