Found video on how to change trans filter
Old Feb 4, 2012 | 08:29 PM
choover82's Avatar
choover82 is on a distinguished road
Default Found video on how to change trans filter
And believe it or not, its on a blazer...and i followed everything this dude did in the video...sure wish I had found this before I started...
Transmission Filter change - YouTube
Looks to be a 92 - 94 blazer
I still havent put mine back together
Old Feb 4, 2012 | 08:49 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
just one thing. dont use any kind of gasket sealer on a transmission pan gasket. look in the video the pan has blue gasket sealer on it when he took it off. thats why it leaked. if it doesnt come with sealer then dont use any!!! if your having trouble with the gasket moving around then just put a bolt in each corner. the make the gasket holes smaller than the bolt. you can thread the bolt through the gasket and it will stay long enough to bolt up the pan.
Old Feb 4, 2012 | 09:00 PM
InsanePyro's Avatar
InsanePyro is on a distinguished road
Haha I just cut my exhaust and welded it back on
Old Feb 4, 2012 | 10:16 PM
richphotos's Avatar
When I did the tranny pan and filter on the 94, It was the first time doing it, So I unbolted the tranny from the cross member, Jacked up the tranny slightly to give me some room, and while my buddy removed the tranny pan. I grabbed onto the frame and pushed on the exhaust with my foot, just to flex it enough to get the pan out. It worked fairly well.. easier going in than it was taking out. got the job done.
Old Feb 4, 2012 | 11:30 PM
choover82's Avatar
well i was wrong. had to unbolt my exhaust but still cant get enough clearance to get pan back on...pissing me off to the point almost ready to call junk yard to come get it...
Ill work more on it tomorrow when its light out...seeing as the fuse for the garage blew and cant find a fuse to work.
Bleh! Next time Ill pay someone to replace the trans filter!
Old Feb 5, 2012 | 01:24 AM
mr.vls's Avatar
I always remove the trans crossmember, he did not show removing and installing the tube seal, I use a scribe to remove the seal if it does not come out with the filter. Like others said no sealent on the transpan ever. Never had one leak on any vehical. The big concern is not to overtighten the pan bolts. You do not want to strip out the threads or break off a bolt head. Even torque all the way around. For the crossmember I use a box wrench at the top of the frame and an Impact gun with a ext and socket to remove the 4 frame bolts. Then the transmount bolt. Support the trans with a floor jack at the tail housing to take the weight off of the crossmember. Rotate the crossmeber and it will drop out of the frame rails.
Old Feb 5, 2012 | 01:40 AM
choover82's Avatar
Well I did that. Removed the cross member, have a bottle jack supporting the transfer case....didnt mess with exhaust getting the pan off, but putting it back on, i find myself stuck with removing the Y pipe. Have no lights in garage, otherwise id still be out there working on it.
Not sure if Ill keep this blazer, becoming more and more of a money hog...I have yet to own a newer vehicle...(that doesnt require all this maintanance.)
Old Feb 5, 2012 | 01:49 AM
InsanePyro's Avatar
Would gasket glue also be bad? I think my cousin used some when we replaced mine...
Old Feb 5, 2012 | 01:50 AM
mr.vls's Avatar
I have an 89 2WD and have done the trans. fluid change at least a half a dozen times. I have not had to do anything with the Y-Pipe for removal or installation. It has been a little while since i have done the filter change. I know the exhaust is very close but I believe I was able to slip the front edge of the pan on first and angle the pan into position.
Old Feb 5, 2012 | 05:24 PM
choover82's Avatar
Its back on and no leaks. Thanks to all who helped out!
Thager
Sep 27, 2013 12:08 PM
hanksta2
Jan 25, 2013 03:57 PM
badpoor
Jan 7, 2011 06:35 PM
doobie98dailydriver
Mar 24, 2010 10:40 AM
shawnwarvet
Aug 7, 2007 08:48 PM
