Front end/ 4x4 help
Old Oct 20, 2008 | 10:24 PM
blazeron35s's Avatar
blazeron35s is an unknown quantity at this point
Default Front end/ 4x4 help
I have a 1991 4x4 s-10 blazer that has a worn out front end? Thats whata local autoguy told me, It wont drive in four wheel drive at all, just grinds, two wheeldrives fine though. It honestly looks like the frontdrivers wheel is about to fall off because of the crazy angle it is leaning inward on.Am I going to have to buy a whole new front axle and swap it out? If so were can I get one and how mush is this going to run? Thanks a bunch!
Old Oct 21, 2008 | 06:14 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: Front end/ 4x4 help
I'd start with that front end and get that corrected then go from there. Doubt that'll fix the 4wd but ...As far as the 4wd manual? Does it light steady/solid on the floor shifter? Grind at that point? Slip shaft lock in? We'll all try to help you with more info. JP[:@]
Old Oct 21, 2008 | 12:08 PM
The indicator light is actualy broken but you can get the lever into 4x4 with some difficulty, once its in 4x4 and you hit the gas to go, it makes this mega loud grinding noise and it stops the truck, almost like some gear in the differential is grinding.
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
evlblkwpnz
Dec 18, 2009 08:26 AM
ComputerNerdBD
Mar 18, 2009 06:13 PM
mikeywaynebygod
Suspension Tech
Dec 11, 2006 11:16 PM
