fuel in cylinders
Old Nov 8, 2008 | 07:40 PM
hazzman52's Avatar
hazzman52 is an unknown quantity at this point
Default fuel in cylinders
i have a 1993 s10 blazer with cpi i just recently put a new motor in it. i went to crank it over and it cranked for a second then stopped. i rolled the engine over by hand and had a ton of gas come out of the exchaust manifold. what would cause the cylinders to fill with gas. the fuel pump runs for two seconds then shuts off when the key is turned on. please help
Old Nov 8, 2008 | 08:20 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default RE: fuel in cylinders
That'd be you're spider injector unit failing. More specifically, probably the fuel pressure regulator and/or the internal fuel supply and return lines. All is located under the upper intake plenum. Use the search function and see what u turn up. Remember you have cpi not csfi, That was used on models '95 and up I believe. Good luck.
Old Nov 9, 2008 | 04:48 PM
Yeah, you have a fuel leak internal to the plenum. If you pull off the upper plenum and energize the fuel pump, it should be very evident where the fuel is coming from.
Old Nov 10, 2008 | 10:45 AM
billyhoe's Avatar
billyhoe is an unknown quantity at this point
definately the fuel line into the fuel pressure regulator.
MAD02
Apr 7, 2013 05:47 PM
craighaz
May 14, 2009 06:59 PM
xoxoydoihavexo
Apr 18, 2009 12:25 PM
95seenbetterdays
Apr 12, 2009 09:39 AM
guillermoariast
Jan 26, 2007 05:26 PM
