fuel pump and radiator on a 94 vortex
Old Aug 7, 2007 | 09:58 AM
green75's Avatar
green75 is an unknown quantity at this point
Default fuel pump and radiator on a 94 vortex
i put a brand new radiator on. in feb. now i have a leak somewhere hoses are tight.i smell antifreeze like a burning smell. what can be my prob?
i have the tank dropped and cant get to the lines to change the pump. what can i do im starting to get frustrated.?
*Combining Similar Threads*
i checked the wiring going to the fuel pump with a tester. and the light was dimm. so i called a local auto parts store. the told me relay.bought one wasnt relay. is there a way to run a direct hot wire to the pump.i also cut the ground wire and connected it back together. the pump was working b4 i put it in the tank. need some insight
*EDIT by swartlkk* - Combined similar threads to cut down on confusion.
Old Aug 7, 2007 | 10:02 AM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: fuel pump and radiator on a 94 vortex
The burning smell of antifreeze, means you probably have a intake manifold gasket leak, which means replacing the intake manifold gaskets. It could be either upper or lower, but most likely lower, since it would drip onto the exhaust (hence the burning smell). i would get this replaced asap and then change your oil because most likely antifreeze also got in you oil, or may while replacing the intake manifold gasket, causing the oil to foam. This should cost around $300 or less at a non dealer service facility. Otherwise it would also be pretty easy to do yourself, just use the search function to find more info on how to do it your self. Hope this helps you out.
Old Aug 7, 2007 | 08:05 PM
green75's Avatar
i got the tank down and hooked up the new pump b4 putting everything together.the pump worked. put it all together tank strapped in go to start nothing no sound or anything. i checked the power i have a very dim light. bought a new relay still nothing how can i run a direct wire to the pump. and where should i run it?
Old Aug 7, 2007 | 09:54 PM
kakn's Avatar
kakn is an unknown quantity at this point
check your ground wire for the fuel pump. my pump stoped working and come to find out "some how" my ground wire was cut. spliced together and it worked. saved me $75 for the pump.
Old Aug 8, 2007 | 06:49 PM
green75's Avatar
i have gas going to the motor. i checked the pressure. im lost. i have spark. i pour gas in the chamber and it will run till that burns out. any ideas
Old Aug 10, 2007 | 09:14 AM
So what exactly have you done? You have multiple threads that all state different things... Please lay it all out here so that we can better help you without reading through all of your threads... Things get very confusing if you keep posting up different threads on the same problem all stating very different trains of thought. Keep it all here PLEASE!!
Old Aug 21, 2007 | 08:47 AM
green75's Avatar
yesterday i turned the key and heard the fuel pump. still no start,or any pressure .im lost i got a pump out of a used blazer. shoul di go buy a new pump and see what happens. i took the pump out of a 92 blazer. i have a 94
bigdaddykane93
Jan 4, 2010 12:03 PM
redneck
Engine & Internal
Jan 22, 2008 03:23 PM
alan98296
May 8, 2007 01:06 PM
jes9999
Jan 1, 2007 06:12 PM
jes9999
Mar 12, 2006 01:40 AM
