Fuel pump testing?
Old Sep 6, 2008 | 03:23 PM
squawfishslayer's Avatar
squawfishslayer is an unknown quantity at this point
Default Fuel pump testing?
I have a '91 4 door T-10 4.3L
Want to test fuel pump amp draw, but do not have G pin in ALDLport to test pump.
Is there an easy way to run the pump, need more then 2 seconds.[sm=headbang.gif]
Old Sep 6, 2008 | 03:32 PM
Default RE: Fuel pump testing?
Pull the fuel pump relay and jump across the appropriate pins. The relay should show which pins are switched.
Old Sep 6, 2008 | 03:44 PM
Thank you Kyle!
Started to suffer from brain fade, should have thought of that.
smallblocks10
Apr 10, 2012 08:07 PM
dobyken
Oct 1, 2010 11:58 AM
Qmulus
Mar 21, 2010 01:02 PM
3D_Illustrator
Aug 12, 2009 03:52 PM
fjdavid
Aug 16, 2007 07:32 AM
