Need fuel pump testing help. 02 blazer
Old Apr 10, 2012 | 08:07 PM
smallblocks10's Avatar
smallblocks10 is on a distinguished road
Default Need fuel pump testing help. 02 blazer
My fuel pump stopped running today so i put a new one in,but it still doesn't run.
Can anybody tell me the right way to check the relay under the hood and the location of the fuel pump fuse? I swapped the relay with the identical horn relay and that didn't help.
I also need to know how to test the wiring at the pump since I can't find a diagram. I do know the gray wire is hot for 2 seconds when the key is turned on.
So far by searching the internet i need to check that stuff,grounds and the oil pressure sending unit also.
GMGIRL
17
Aug 13, 2013 10:56 AM
dobyken
Oct 1, 2010 11:58 AM
Qmulus
Mar 21, 2010 01:02 PM
3D_Illustrator
Aug 12, 2009 03:52 PM
squawfishslayer
Sep 6, 2008 03:44 PM
