fuel pump troubles
fuel pump troubles
I have a 1989 s10 4 x 4. Was running fine and now won't start. Checked for spark had plenty. Pulled the gas line going into tbi and no fuel flow. Hoped and prayed for a clogged fuel filter. Replaced it and still no gas flow. If I pour some gas into tbi the old gal will fire right off till it burns the gas out then dies. I assume it has a electric fuel pump which with my luck will be in the gas tank that I just filled up. How can you tell if it is bad? Is there some kind of relay that might be bad? Does the fuel pump start pumping when the key is turned on? Any help will be greatly appreciated! Thanks
RE: fuel pump troubles
You should have a fuel pump fuse and a fuel pump relay.
Kyle, Where would the fuel pump fuse and relay be located at? Thanks, Tim
Whats the size of the engine?
It is a 4.3 Thanks
Kyle, Thanks for the info!! Happy Easter, Tim
No problem!!
BouncingRadical
14
11-27-2015 12:30 AM
cide
11-07-2009 01:26 PM
mytruck2
12-13-2006 04:50 PM
