gauge cluster
Old Jan 6, 2008 | 07:58 PM
92 blazin's Avatar
92 blazin is an unknown quantity at this point
Default gauge cluster
hi i have a 92 s10 blazer with the digital cluster and was wondering if they make and converting kits from electric to the manuel cluster or can u just drop it in?
Old Jan 6, 2008 | 08:13 PM
Default RE: gauge cluster
Yes you can, but it does involve wiring modifications.
You will need to disassemble the dash and remove the stock cluster. The digital cluster has a 32 pin electrical plug which will need to be cut off. When you get your analog cluster, make sure to get the 18 pin plug with atleast 4" of attached wiring. You will have to move the wires into another cavity in the dash support to allow for the assembly of the analog cluster.
I believe that most of the wire colors will match up from harness to harness, but things like the the cluster illumination may need to be jumpered off of the headlight switch. There will be two Lt.Blue wires and two Blue wires (left and right turn signals respectively) from the 32 pin harness. Splice the two wires of like color together when connecting them to the 18 pin harness. Also, the high beam wire and the seat belt light may be reversed on some vehicles (Lt.Green and Yellow respectively) so check for proper operation of these bulbs before permanently connecting these two wires.
blazerguy09
Jan 7, 2015 03:26 PM
Lidberg
Aug 10, 2011 01:01 AM
3kidblazer
Feb 1, 2009 11:22 PM
offroadin974wd
Jan 22, 2007 10:37 PM
magtec
May 5, 2006 06:48 PM
