Getting Frustrated - Fuel Leaking from relief valve
Old Jul 21, 2012 | 02:19 PM
jfrust64's Avatar
jfrust64 is on a distinguished road
Default Getting Frustrated - Fuel Leaking from relief valve
Hi all,
I posted last week about fuel pump issues on my 94 4.3 CPI. Got everything back together, turned the key, the car started and fuel started pouring out of the pressure relief valve.
Any guidance here would be greatly appreciated as I replaced the spider assembly last year...would hate to have to rip this apart again.
Thanks for your help...
Old Jul 21, 2012 | 02:29 PM
Fuel leaking from the valve means that the valve and possibly the body itself needs to be replaced.
Old Jul 21, 2012 | 02:32 PM
jfrust64's Avatar
Where can I get this?
Old Jul 21, 2012 | 03:24 PM
jfrust64's Avatar
Thanks...I tried to tighten up the valve stem but that didn't help either. The auto parts store didn't have the part. Can I replace the stem or is it keyed to a particular pressure?
This doesn't seem like it should be this hard to deal with.
Thanks again to all who can help
Old Jul 21, 2012 | 04:14 PM
That is part of the internal fuel lines typically called the nut kit.
Old Jul 21, 2012 | 05:21 PM
jfrust64's Avatar
replaced the valve stem and everything seems to be fine...thanks again for your help.
You got me back on the road!!!
Old Jul 21, 2012 | 05:54 PM
Hopefully you didn't just use one from a tire valve... You need one that is meant to be used with fuel.
Old Jul 24, 2012 | 08:00 AM
jethro610's Avatar
jethro610 is on a distinguished road
i have a 2000 Zr2 blazer replaced fuel pump if i tighten gas cap pressure builds up and fuel leaks from small black box in front of fuel tank already replaced charcoal canister . if cap is let loose fuel does not leak the fuel pump lines are all a different size so u can't mess up when hooking up line not sure whats going on leave cap loose for now any ideas
rrcher
Apr 3, 2011 04:09 PM
dinomotz19
Apr 5, 2010 09:07 AM
ron51
Feb 22, 2009 02:14 PM
2klt
Apr 15, 2006 05:22 PM
2klt
Engine & Internal
Mar 9, 2006 04:40 PM
