has any 1 used this stuff before ?
Old Nov 29, 2011 | 07:02 PM
  #41
xgiovannix12's Avatar
yea it is less then 5 ohms every thing on the passenger side is less then 5 ohms
I tryed the defrost again and the wire got real hot
it think i need to check for shorts
I give for tonight =(
the passenger side body wire is an ground right ?
Old Nov 29, 2011 | 07:06 PM
  #42
If resistance checks good, like you said, it might just be a poor connection AT the strut.
To make sure which is positive and which is ground, unplug both connectors, turn on the defroster, one side will show battery voltage, the other will show ground.
Old Nov 29, 2011 | 07:11 PM
  #43
I found this
apparently the ground is the wire that is heating up
Old Nov 29, 2011 | 07:16 PM
  #44
The ground wire must be the same, or preferrably larger than, the positive wire. The ground wire needs to carry the load of the defroster to ground. If it's smaller, or has a poor connection, it will heat up.
EDIT: After looking at the schematic, here's something you can try....
Unplug the passenger side connector. Hold the black probe of your Fluke to ground, touch the red probe to the tab on the glass on the driver side.... resistance again, should be less than 5 ohms.
Old Nov 29, 2011 | 07:18 PM
  #45
yea i will check every thing again tomorrow after work
Imma pull the rear panels off and see what i find
Im also going to clean all the connections with sand paper or a steal brush
what ever i find 1st
Old Nov 30, 2011 | 01:50 PM
  #46
ok i just started working on the truck again
I checked the resistance and its over 5 ohms now i have no power any where
every thing else works and i cant find a fuse
Old Nov 30, 2011 | 01:57 PM
  #47
Unplug the passenger side connector from the strut. Hold the black probe of your Fluke to ground, touch the red probe to the tab on the glass on the driver side.... resistance again, should be less than 5 ohms.
EDIT: This will check the ground that is available to the grid.
Old Nov 30, 2011 | 02:04 PM
  #48
ok i will try that
i checked the fuses and every things good I hear the relay click so that must be good
Imma go unplug the passenger side body wire and test it like you said
Edit: k i tested the passenger side body wire (ground) to the tab on the window and it shows 66.6 ohms
when i tested it it was unplugged from the strut
Edit 2: I played with the switch and the light one go on I dont got any power by the glass
i checked the fuses and there all good
Im very angry =( its cold and its starting to snow
Old Nov 30, 2011 | 02:34 PM
  #49
Start checking resistance in the strut, then the wire from the strut to the body ground. You're looking for a loose connection, or a partially broken wire. It will not be real obvious because there is some continuity, you might have to wiggle connections/wires when checking resistance.
EDIT: This will test for ground problems, once that is repaired, then we'll move on the positive.
Old Nov 30, 2011 | 02:45 PM
  #50
i connected the ground to the strut and i checked all the connections and the tab on the passenger side and i got 0.5 ohms on every thing
I think imma pull the rear panels off to see whats going on in there
The tiny led on the switch wont light up any more and i still not getting power in the back
