has any 1 used this stuff before ?
Old Nov 30, 2011 | 02:51 PM
  #51
Let me know what you find behind the panels, loose connection etc.
The LED pilot lamp on the switch gets its voltage from the exact same place as the power wire going to the grid. If the LED is not lit, it's either burned out or the grid is not getting voltage. Do you hear the relay click when you select "ON"? (ignition must be ON)
Old Nov 30, 2011 | 02:55 PM
  #52
xgiovannix12's Avatar
yes i hear the relay click when i turn the switch on
yesterday iwas getting power every where now im getting nothing
makes me wanna go crazy
Imma go out and take the driver side panel off if the snow falls harder imma call it a night its also getting dark
Ok i got the driver side panel off I had to remove the whole rear panel since it was one piece
theres a 12 gauge wire going into a rubber hose and every thing looks good
nothing was ever touched in there
it had that weird rubber material from the factory
I was going to get the point of the test light and make a tiny hole to see if i got power but i came in to warm up a bit and to update what i found
Last edited by swartlkk; Nov 30, 2011 at 04:36 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 30, 2011 | 03:38 PM
  #53
Probing through the insulation is not such a hot idea. If moisture gets to the copper wire, it will corrode quite rapidly. Better to check resistance from each end of the wire. If it's bad, put in a whole new wire. I think I'd use 10 gauge
Old Nov 30, 2011 | 03:41 PM
  #54
the wire i was talking about comes from the front to the rear of the truck
I really thinking the switch is the cause Imma test each wire on the switch see what happens
edit: this is the switch http://www.ebay.com/itm/93-BLAZER-IN...item415df387f7
Edit:2 I tested the wires on the switch i got one with direct power and out of 6 wires only 1 get power when the switch is on
Old Nov 30, 2011 | 03:58 PM
  #55
From post #43.....
orange with black tracer should show battery voltage at all times.
Pink with black tracer should show battery voltage with ignition in RUN position.
The solid black wire should show less than 5 ohms to ground at all times.
If you only have voltage on one terminal, check the fuse and circuit breaker.
Old Nov 30, 2011 | 04:01 PM
  #56
Ok i just came in for the night
I decided to play with the switch a little bit with the truck on
and the defrost led went on
I shook the switch a tad and it was going on and off the relay was clicking while i was moving it also
I think imma try to get a switch
Edit: I went outside and my mom tagged along I made her hold the test light on the driver side body wire and i played with the wires on the switch
turns out when i play with the wires the test light flickers on and off
Looks like imma need a new switch
Old Nov 30, 2011 | 05:04 PM
  #57
OK, the switch should take care of the intermittent positive voltage to the grid, but there's still an issue with ground. Where the grid connects to the left, (ground) strut needs to be less than 5 ohms to ground. If it's higher, it will probably be easier to run a new 10 gauge wire with an eyelet soldered to the end and stick it under a bolt head or a sheet metal screw:
Old Nov 30, 2011 | 05:07 PM
  #58
connecting the ground to the strut and it shows 5 ohms I will test it again tomorrow when i put my panel back on
I remember i was getting more then 12 volts going into the grid so the switch might of caused that
Edit: Ill update ya tomorrow on the ground
and i do really wanna thank you again for your time and patience with my stupidity
Old Nov 30, 2011 | 06:18 PM
  #59
You need to understand how things work so you can figure out why they don't... You're the one fixing it, I'm just helping you understand it
Old Nov 30, 2011 | 06:33 PM
  #60
agreed thank you once again =)
