Heater Stuck on Floor setting
Old Dec 2, 2007 | 04:13 AM
89K5's Avatar
89K5 is an unknown quantity at this point
Default Heater Stuck on Floor setting
Anytime I turn me heat on no matter what setting it stays on floor for some reason. Today we got freezing rain and snow so i tried to turn it on defrost but it stayed on floor. And when it's on high you can hear it but to me it seems like its not blowing that hard. How can I fix the heater problem or check it and in a way it doesn't bother me that much cause usually when I have the heat on its on floor anyways but when the windsheild is all foggy and I can't see out of it.
Old Dec 2, 2007 | 03:55 PM
Default RE: Heater Stuck on Floor setting
This is typical of a lose of vacuum to the hvac headunit.
Old Dec 2, 2007 | 05:29 PM
89K5's Avatar
Is that to fix the blower or the heater switch?
Old Dec 3, 2007 | 02:15 AM
Chevy Lover's Avatar
It's to fix the mode control doors so you can direct the air to defrost or floor.
Listen under the dash for vacuum leaks, check for loose vacuum hoses at the heater box behind the glove box, you may need to remove the heater control unit in your dash to check the back of it for loose vacuum hoses.
Old Dec 15, 2007 | 03:29 PM
ChoochCharlie's Avatar
ChoochCharlie is an unknown quantity at this point
My '92 has the same problem. The bracket that connects the vacuum solenoid to the flap that cuts off the floor vents is broken. I haven't figured out a way fix it and have not searched for a replacement part. I just popped bottom off the floor vent and stuffed in a rag for now.
gwkelly3
Aug 29, 2012 12:08 PM
Glorf
May 20, 2012 08:05 AM
gomfrddy
14
Jun 11, 2011 12:18 AM
jojocarreno
May 27, 2011 12:27 PM
gmbwrenchn
Oct 28, 2010 07:30 PM
