Heavy Mis-fire While Driving
Old 09-09-2009, 02:11 PM
cjmor1804's Avatar
cjmor1804 is on a distinguished road
Default Heavy Mis-fire While Driving
Ok, well I've been trying to figure out this problem, but no one seems to know what it is. The truck idles and revs up perfect when it is in park or neutral. As soon as it is in gear, it runs like its only using 5 cylinders and backfires/mis-fires through low to mid rpm's. What all would cause this???Plugs are new, cap/rotor/wires are near new. Has a new EGR valve and new fuel filter. It's getting plenty of fuel, but I'm not sure about spark. When I changed the ignition coil, things got extremely worse, so i had to put the old one back on. Wires are not touching metal and there is no viible spark jump. No check egine light is on either. Any help here???
Ignition module?
Pick-up coil?
Exhaust? (it is broke at the y-pipe and missing tail-pipe)
Old 09-10-2009, 09:33 PM
cjmor1804's Avatar
well, having a new cat-back exhaust installed helped a little, courtesy of my boss. the cat wasn't replaced so maybe that will be next.
Old 09-11-2009, 12:24 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
what style distributor do you have? do you have the one with magnets in it? if so, they tend to crack and then cause misfires like you described. very common problem but not many know about it. this magnet style dist was used until 1994 but i dont know how early it came out...
Old 09-11-2009, 10:47 AM
cjmor1804's Avatar
Um.. all i know is it's an electronic distributor for a 1989 S10 Blazer 4x4 (4.3TBI)
Old 09-11-2009, 01:05 PM
ok i just looked up the part number for a 1994 and a 1989 witht the same 4.3 and they are the same distributor part number. which means youhave the magnet type dist. so you may want to consider look into the dist. as the problem...just a thought
Old 09-11-2009, 02:16 PM
cjmor1804's Avatar
Yeah, i think i will pull the cap off and take a look, i was thinking about taking the ignition module in for a test anyways. hopefully i can get to it this sunday.
Old 09-14-2009, 02:46 PM
cjmor1804's Avatar
Well, i knew this problem would be something so simple, that i would kick myself in the *** for not having it fixed sooner. the new plug wires i had put on were little crappy 7mm's, so the insulation was not the greatest, causing almost un-noticable spark jump. I replaced them with higher grade 8mm wires and now things are running better than ever.
Klturi421
08-25-2012 09:30 PM
95blazer91
02-27-2011 01:52 PM
tall_ish
11-20-2010 09:05 PM
JPM
12-03-2009 07:06 PM
wienerdog
11-12-2008 08:28 AM
Quick Reply: Heavy Mis-fire While Driving
