Help Save My Baby
Old Jan 19, 2016 | 03:18 PM
luvgert1991's Avatar
luvgert1991 is on a distinguished road
Exclamation Help Save My '91 Blazer
I have a 1991 S10 Chevy blazer. My grandpa gave it to me and it is a great vehicle. I have been driving it for a while and the cluster (digital) has been..... well it has not worked really at all since I have had the vehicle. None of the display works my first question is; is there a procedure for converting a digital cluster to an analog cluster? I have seen posts for going from analog to digital but not the other way around. If there is such an operation, could someone point me in the right direction?
My second question is; Why doesn't my blazer start? It seemed like out of nowhere when I tried to start it, it would not start. I checked the fuses and I can't remember which fuse it was, but it would keep blowing every time I tried to start the vehicle. The engine cranks but will not fire.
Any comments or concerns? If there is something I should try, please let me know!
Thank You!!
Old Jan 19, 2016 | 08:56 PM
richphotos's Avatar
Which fuse blowing would be very helpful on us helping to figure it out.
As for converting from digital to analog. Just reverse the steps in the procedure to convert from analog to digital.
Old Jan 20, 2016 | 07:57 AM
Default The Fuse
It is the IGN/gage fuse that keeps blowing.
Thank You!
Old Jan 21, 2016 | 05:28 PM
Rusty Nuts's Avatar
It sounds like the gauge cluster is the problem. When my 91 jimmy's digital dash went out on me I had it repaired by an automotive instrument company in my area (SPECMO). They repaired it in a couple days for $160. They kept the odometer at the same mileage and it performed flawlessly for 12 more years. It still worked when I scrapped the truck.
I don't know about swapping to analog because I wasn't willing to give up the coolest turn signal indicators ever put on a vehicle. I still miss them.
Old Feb 11, 2016 | 02:55 PM
Default Fixed
Bought and installed a new ignition switch and had the cluster repaired. This did not fix the problem even though it was nice to have the cluster working again. I put in a different ignition module and it runs and drives just like before. Thanks for all of the suggestions!
dyeraudio
Feb 10, 2010 09:03 PM
oisinirish
Mar 2, 2009 07:27 AM
mdecker
Feb 17, 2008 05:36 PM
Outsydr
16
Dec 15, 2007 02:28 PM
rriddle3
Sep 20, 2007 09:35 AM
